Hey all, on my way to work this morning my clutch pedal stuck to the floor.. Much like when a slave goes (had this happen in december) but I still have all my fluid... When clutch is depressed nothing happens it still moves... I have to start the truck in 1st gear and thr starting ia turning the truck unless I'm pointed down hill and can jam it into a gear... I don't see any leaks ans my fluid is topped up!?
How does the hydraulic line connect to the MC on a 1989 F-150? It looks like there may be a small set screw on the MC just below where the line connects.
I think that is a roll pin. You will need a small pin punch and a hammer to remove the roll pin.
I hope memory is serving me correct AND it is the same as my 1988.
