370 V8 fuel pump weird thing on it
I just took fuel supply line off and getting no suction on my finger. also stuck it in gasoline and its no pulling.
aNYWay this is what is it in:
http://ecx.images-amazon.com/images/I/71wMrKdzMxL._SY355_.jpg
is thing on top a filter or some vacuum device??
Is it better to use a regular one off a 460???
That's the fuel filter - you remove the can, and replace the element inside of it.
Can't say if you can use one from a 460, but since they are the same engine family, chances are, yes - as long as you have room for it, and the pump arm is the same. If the new fuel pump doesn't have a built-in fuel filter, add an external.
One note, looking at that picture, the fuel filter is way up high, maybe to clear the engine mount or some other chassis part? Make sure you have clearance for the new pump.
Just buy a stocker and think about it again in 10 years or so...
Serving suggestion....
I was thinking since i don't use the truck all time it will be easier to drain fuel out and run it dry because of the ethanol fuel that is being used today. It would also be easier on the starter I would think. Also i can use an oil pressure switch so when engine is not running pump will not run like most vehicles with electric fuel pump.
It not so easy to change this pump. I had to remove oil filter and drain radiator to remove lower radiator hose to get to the 2 bolts. I had to do it mostly by feel because I couldn't see the bolts.
Dodge/Cummins
06-19-2008 12:31 PM
