I'm Happy with My 6.2L
A quick back story, just pulled our '30 tandem dual gooseneck trailer, 7,500#s empty, loaded down with tree length firewood logs about 200 miles. I didn't have accesses to a scale, but I'm quit sure that I was well above the truck's 22,000# GCWR and the gooseneck's hitch rating, 2014 F-350 SRW reg. cab 4x4 with 4.30 gears. Lastly, the first time I had the auxiliary springs touching the pads front and back at the same time because of the heavy pin weight.
The 6.2 is very capable motor and when pulling I believe the 4,30 gears are the way to go. We gross around 24400 when pulling and when on mountain grades I'm at the edge of its capability but I'm still happy with our decision to stay with a gas motor. If you haven't used it yet in the manual mode when towing give it a try, it's way better than tow haul.
Denny
Denny
Yeah, Highway 385 between Sidney and Bridgeport, Nebraska, is fairly hilly. On the hilly parts I just locked out 5th and 6th gears with the cruse control set at 65 m.p.h. The truck maintained 65 m.p.h better than expected.
Denny
Denny
Just push the negative button on the shifter repetitively and you will see the gears dropping off on the info screen. push plus button to add them back.
trailer loaded maybe 9,500 and 1500 in truck. ( 800 being motorcycle in truck bed )
Ohio to South Carolina.. and the Hills and Never been to the Carolina's
When I'm pulling it hard in the manual mode I like to keep it between 3 to 4.5K. I've done it enough I don't even have to look at the tach anymore I just listen to the torque throb just like the muscle cars of days gone by. If you ever pulled one for all its worth you will know the sound I'm talking about.
Denny
Yes, the last automatic transmission vehicle I owned was 1990.
and have only owned 3 automatic vehicles in 47 years...
and for muscle cars..
high school 64 Chevelle SS 327, 4 speed
then 65 Impala SS 409, 4 speed.. (2) 4bbl's
from 1988 to 2008 1979 Corvette (I restored) 383 with 5 speed manual..
Denny
If Ford still offered the manual transmission, I'd have one. But, with that said, these modern TorqShift trans. is so much better than the old E4OD. For me moving the button all the time in manual mode would get old fast. Plus, how long is it going to take before that little micro-switch to break under constant use?
Denny
