Rear shackle flip ?'s
I have a few questions regarding a rear shackle flip on a 77 F-150. What parts are needed? Do you use the front shackle from the rear springs? Will it flex better than the stock setup? Does anyone have pics of theirs or a link to some pics? I need to know what to get from the junkyard because I'm going to go get parts tomorrow so I have something to do this weekend. I'm in the process of getting a buddies truck ready for Memorial weekend and want to get rid of the stock blocks.
Originally Posted by FordPerf300
You need the F250/350 front of leaf hanger
The search feature is not back to normal yet, too bad because there are a few really good threads about this.
there are a few ways to do it....first (and easiest) is buy the kit from Sky. I did that b/c the brackets are so much stronger.
or
remove rear shackle and then on the bottom of the hanger cut a hole big enough so that the shackle will slip up from the bottom...which works but is not very strong.
or
(what most people do) go to a junkyard and find a set of rear axle/front hangers....they will drop the farthest and then get your angle right, drill frame, then bolt up. just use your existing shackle!
yes you will get a good amount of lift with any of the ways without sacrificing flex and ride. As Ivan said...check out my gallery for pics of the kit from Sky or Pro's gallery of the ones he made. have any other questions, i would be glad to help.
-jason-
Edit: here is a shoprt cheesey vid clip of how much flex that shackle flip got me http://www.yousendit.com/d.aspx?id=2...6E10F2CE1AE26D
or
or
-jason-
This is most likely what we will end up doing. We will also most likely beef up all the parts with some 1/4" plate. I found out today that the rear shocks are too short, so we will have to re-work the shock mounts.
Originally Posted by mark a.
What is all of this going to do to the pinion angle ? And will it move the axle forward too much in the fender wells ?
Originally Posted by GloryToTheSouthland
Id heard that shackle flips were harder on your springs. Is that true?
-jason-
Many vehicles came with with the shackles pointing down so i doubt it will introduce any more stress than they already feel. My axle got pushed way towards the fender, i installed the ORD zero rate leaf that allows install the axle back 1.5", helped a bit but i'm prolbably also going to have to drop the front hangers.
correct website is www.sky-manufacturing.com
fishmann what do they mean by every inch of movement takes away 1/2" of lift. So could I get 2" springs since its a 4.5" lift with the shackle. Or could I make the shackle lift only 2" and use 4" springs.
it means that when you install their kit the way they prescribe there are 2 holes to use....if you use the hole towards the front of the truck then it will add 1/2".....if you use the hole towards the back of the truck it subtracts 1/2"
best thing to do is to do the shackle flip and then drop the front hangers as was previouslyt mentioned for another couple of inches
-jason-
-jason-
