Questions before aftermarket sound system.
So I hate the stock sound system in my 2013 superduty. I wanna keep the stock headunit with the nav, sync and mytouch. I wanna keep all that and my question is will pulling out all the stock sound equipment and replacing it with a an aftermarket amp and subs and another amp and battery for the door speakers alter any of the functions of the stock headunit. I read somewhere that the stock amp had something to do with the sync but I'm not sure
If you don't get an answer here, call Crutchfield Crutchfield: Car Stereo, Speakers, Home Theater, Pro Audio, 4k TV
And as them for some assistance, they can tell you every thing you need to know and more.
Line-level connections would be my suggestion. it's best to find an amplifier that already has the option (like most Alpine amps). The stand alone adapters generally pop or have noise issues.
After Market
The head unit will continue to work with after market speakers and amps. But it might now solve the sound quality issue.
I ended up replacing my head unit after upgrading my speakers. I was not happy with the sound after I did the speakers and the amp. I still have sync and steering wheel controls.
on
I used an LCQ-1 to run a couple of 1,000W amps. 1 - 4 channel for the speakers and 1 for the subs.
LCQ-1 - AudioControl
It's OK, works as advertised but there is very slight noise when the vol is min. Otherwise the sound is good.
If I had it to do over again I would replace the head unit.
WOW is all I can say. I think my truck as as good a sound system I have every heard in a auto of any kind, volume no shortage of that at all. I hook into my fone and play the music I have on it, and I listen to everything. Enjoy your sounds, hope I get to hear one of these upgrades someday to see how its different...
Thats the rub
My wife car has that kind functions built into radio display. I personal hate the multiple display controls. It requires more attention while driving to make changes. Whats going on is the Radio is displaying information via a interface that talks to the on-board computer which in turn controls the device like Air condition seats. I don't know of any radio/head unit that has that level of integration. My radio will display gauges and some other small stuff from the on board computer. But not the level of control you want.
It is possible for a company to build the interface, not sure if its profitable.
I just put a Kenwood deck in my 2008 f250.....mind you my truck doesn't have all the bells a whistles of a new truck like yours....but long story short you should be able to maintain all the stock functionality with an upgraded stereo unit...it's all in the interface module that you chose. Google idata link maestro modules.......they retain all stock functions like steering wheel controls, sync and climate control functions etc.
No.
From what I can tell from ilink website, they only support lower end audio systems. Not myford touch in Lariat, KR or above.
What part of the system do you find unacceptable? If just the sub, that's an easy fix.
The speakers aren't loud enough and anything above half volume they just kinda get scratchy and it sounds like they'll go at any moment. The stock sub is a joke. In my last truck I had 2 10 inch kenwood subs a kenwood amp, kicker door speakers all the way around and a pioneer avic 7000 nex head unit. I wanna get that same sound volume and clarity in this truck but be able to keep the same headunit and functionality that comes with it.
on
