1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Sway bars, who has removed them and how does it handle?
Old 10-17-2015, 11:49 PM
v10tritanium's Avatar
v10tritanium
v10tritanium is offline
Just debating wether I should take them off or replace them with larger ones and where to find them for a 6 inch lift.
Old 10-18-2015, 01:17 AM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
every time I've ever removed them from any vehicle, the vehicle reacted like a drunk strolling down broadway. all over the place with tons of body sway. great off-road for when you want the suspension to act like a slinky...dangerous and scary on the highway in a 8,000 lbs+ rig
many time guys install a lift with new, stiffer springs and it fells like you don't need a sway bar anymore. Not true!
as far as the lift, unbolt your front links and bolt them to the bottom of the frame. that will account for up to a 4" lift. many lift companies also sell longer links. unless you are into truly hauling heavy over long distances, the OEM sway bars are decent.
here is a picture of how to re-arrange the sway bar link mount on 99-04 models to account for extra lift up front. you can see where it was previously inside the frame rail. All I did was unbolt and move to the bottom of the frame rail. worked great
Old 10-18-2015, 05:30 AM
NYCruiser's Avatar
NYCruiser
NYCruiser is offline
Front sway bars are mandatory. Rear...not so much.
Old 10-18-2015, 07:32 AM
Duwop's Avatar
Duwop
Duwop is offline
If you use the truck bed for hauling loads you are going to want the swear bar hooked up as when loaded without being hooked up you are going feel the difference.
DogRidesInBack
10-06-2017 01:13 AM
good to doo
01-03-2015 05:43 PM
icentropy
05-03-2014 10:57 AM
crazed87bronco
06-22-2011 12:49 AM
christaylor
Offroad & 4x4
06-10-2004 10:50 PM
Quick Reply: Sway bars, who has removed them and how does it handle?
