8BA Pan and Pick up
  #46
Old 12-29-2015, 08:01 AM
F1 Mike's Avatar
F1 Mike
F1 Mike is offline
Ross.
I still have positive ground so hooking up a negative ground solenoid moves the contactor the wrong way. I really need to change the polarity but was trying to do things one step at a time. In your diagram having the wrong polarity moves the contactor down instead of up.
  #47
Old 01-02-2016, 01:44 PM
F1 Mike's Avatar
F1 Mike
F1 Mike is offline
New plugs, cleaned and re-gapped the points and re set the timing. Fired right up.
<iframe width="560" height="315" src="https://www.youtube.com/embed/wUz_8-e2Mo0" frameborder="0" allowfullscreen></iframe>
  #48
Old 01-02-2016, 02:49 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
Jolly Roger Joe is offline
Sounds good Mike! Glad you got it running.
  #49
Old 01-02-2016, 03:24 PM
52 4x4's Avatar
52 4x4
52 4x4 is offline
Originally Posted by ALBUQ F-1
I can't think why a solenoid would care about polarity. I assume you have the later style two-wire starter button that sends power to the solenoid? I'm using the stock '52 solenoid on 12v neg grd
I'm with Ross on this one. I had to change to neg. ground due to installing a neg. ground radio. This was nearly 40 years ago, and I still have the original starter solenoid operating on 6V neg. ground. - Bob
  #50
Old 01-02-2016, 04:27 PM
F1 Mike's Avatar
F1 Mike
F1 Mike is offline
If your solenoid is grounded by the mounting bracket like mine it matters. If you change the polarity on an electro magnet it will reverse the direction of force (movement). Google Ampere's right hand rule. If you reverse the polarity the contactor will move in the opposite direction.
  #51
Old 01-02-2016, 06:26 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is offline
Congrats on the first run, Mike!
Do you still have your old solenoid? Could you cut it open to see how it works? I think the typical diagram with a moving core is a simplification of how they actually are constructed.
PS -- all 51-on Ford solenoids are grounded thru the bracket
  #52
Old 01-02-2016, 08:39 PM
49fordv8f4's Avatar
49fordv8f4
49fordv8f4 is offline
F1 Mike, The '51 and earlier solenoid that ground thru the bracket will work fine with the polarity switched to negative ground. I used one for years on my '47 COE.
  #53
Old 01-02-2016, 08:52 PM
F1 Mike's Avatar
F1 Mike
F1 Mike is offline
I'm still using the old solenoid, I cleaned it up good enough that it's working OK. I have one on my other truck that I can take to pieces. I'm still not convinced. I tried 2 other solenoids, one brand new and neither would switch. I can think of at least one way that it would work either way. I'll update tomorrow.
jhaas63
02-03-2013 07:58 PM
Stan Balafas
08-26-2012 12:59 AM
tim.beery
02-14-2012 01:54 PM
Ford_Six
01-01-2012 12:23 AM
snipa
10-05-2006 01:44 AM
Quick Reply: 8BA Pan and Pick up
