No Spark on my 1966 Econoline Pickup's 240 Inline 6
Hey guys, posted this here:
https://www.ford-trucks.com/forums/1...nline-6-a.html
without realizing there was a van/Econoline section...doh!
This seems to be a common thing lately, looking at the few active threads here haha.
I am near completion on my '66 Econoline 5 window rebuild and just finished the full rewiring (what a nightmare) and all seems to be OK.
However, when I crank the engine over to start it I am getting no spark to the plugs.
I have put a new condenser and points on without any success.
I tested the coil via attaching a spark plug to the center distributor wire and attaching a wire from the "-" on the coil directly to the battery "-" and got a spark each time on the plug so the coil appears to be OK as do the plugs.
I do not have a dummy light setup but rather an actual ammeter on the dash so I am not wiring up the stator from the voltage regulator to the alt "S" but instead wiring it to a termination block that has the ignition wire and coil going to it as well that leads back from the ignition switch to the fuse block.
I have drawn up my current wiring, can you see any issues or offer any suggestions?
Cheers in advance!
Cheers in advance!
All good, new plug wires and it started right up!
Thanks for everyone's help.
https://goo.gl/photos/9spyWY3BrVp8GytL6
Kwyckoff
13
03-08-2020 04:51 PM
Udonitron
28
10-16-2015 09:06 PM
76blue
10-26-2009 11:48 AM
tjs_79ford
09-20-2009 11:30 AM
