1997 Expedition High Beam Failure
Old Oct 15, 2015 | 09:44 AM
rynejb72's Avatar
rynejb72
I am new to posting on the forum. I have a 1997 Expedition that every time I replace the #16 fuse it blows when the high beams are on. It seems that it happens only when in drive and accelerating from a stopped position. I wonder if it could be either the clock spring or the multi-switch cause the short. I checked the wires on the headlights and they are fine. Again the high beams work when the truck is sitting still and the fuse is new. Has anybody heard of something like this happening before?
Old Oct 15, 2015 | 02:36 PM
Franklin2's Avatar
Franklin2
If it's the high beam fuse out in the underhood fuse box, then no it would not be a problem at the headlight switch or the multi-function switch/steering column area. That underhood fuse is after all that.
Old Oct 15, 2015 | 04:13 PM
rynejb72's Avatar
rynejb72
It is the fuse in the inside under the dash that keeps blowing. I tested the alt and now it seems to blow every time I turn the high beams on.
Old Oct 15, 2015 | 10:36 PM
rynejb72's Avatar
rynejb72
Okay I replaced multi switch to be sure that was not it. Still blowing fuse #16
Old Oct 16, 2015 | 08:58 AM
Franklin2's Avatar
Franklin2
It still shows that fuse after the column/multifunction switch.
JasWood
Jul 29, 2009 07:10 PM
roree
Jul 10, 2008 02:51 PM
76 F-150 390FE
Electrical Systems/Wiring
Mar 20, 2006 07:21 AM
rebel_gtc
Aug 4, 2004 02:59 AM
