AC/Vents opening/closing on their own - Ford Truck Enthusiasts Forums
Old 10-09-2015, 12:11 AM
F350GK
F350GK is offline
F350GK is starting off with a positive reputation.
Hello. I have a 1995 F350 crew cab. When driving the air/ac vents will stop working from the middle areas and only blow from the defrost vents.
What happens is at speed or under load the vents open/close on their own.
For instance. I can be driving at 60mph. then at 70 the middle/dash vents stop flowing and you can hear some sort of flap open/close and the air will only come out of the defrost vents. Let off the gas and usually the air flows as it should.
Not sure how to trouble shoot this.
any help is appreciated.
Old 10-09-2015, 12:38 AM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is online now
White 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputationWhite 97 xlt has a superb reputation
Welcome to FTE!!!
You have a vacuum leak!!
The most common vacuum problem on these trucks seems to be a white plastic line that runs on top of the A/C box under the hood, these like to get brittle and just crumble if you touch them, you should be able to repair it by replacing the bad sections with rubber vacuum line from the parts store. I hope this helps!!!
Old 10-09-2015, 12:46 AM
F350GK
F350GK is offline
Thanks a lot for your reply. However. I'm not sure where to start or what to look for. When looking under the hood, would this be near or behind the battery? A little confused where to start.
Old 10-09-2015, 01:11 AM
F350GK
F350GK is offline
I think I found what you are talking about. Hard to see in the photo but yeah, this line is brittle and broken. It runs into some type of wiring harness that looks pretty tough to get into. Could I just cut the the line, remove the bad section and replace with new? Or does the whole thing need to go?
Old 10-09-2015, 01:13 AM
88XLTLariat's Avatar
88XLTLariat
88XLTLariat is offline
88XLTLariat is starting off with a positive reputation.
Yep. You found it. Here's a helpful link:Vents are dead - FSB Forums
Old 10-09-2015, 01:39 AM
White 97 xlt
The factory line is usually in pretty good shape inside the harness, what you could do is get as close as you can to the harness and replace it with rubber line, then if trouble shows up later you can always go farther..
That's what I did, I replaced it as close as possible to the harness in 2005 and it is still working fine..... YMMV
Old 10-09-2015, 02:05 AM
F350GK
F350GK is offline
Thanks for all the help. That line was indeed brittle and toast. Trippy how it was so related (mostly) to acceleration at EXACTLY 70mph. I'd get hot and slow down!
Looks like the line is good a few inches before the harness so I will start with replacing with a rubber line and see what happens.
wish me luck.
Old 10-09-2015, 10:36 AM
choate's Avatar
choate
choate is offline
choate has a good reputation on FTE.choate has a good reputation on FTE.
That white line? Maybe that's what's wrong with my temp **** being off alignment? That plastic white line in your photo is gone on mine. Completely toast
Old 10-09-2015, 10:37 AM
choate's Avatar
choate
choate is offline
Originally Posted by White 97 xlt View Post
Welcome to FTE!!!
Just read your second paragraph. Didn't see it at first. That's definetly bad on mine. Thanks
Old 10-09-2015, 01:14 PM
F350GK
F350GK is offline
Next steps...?
So what's next... Removed the old bad line. Replaced with new. Same problem. Under acceleration defrost vent only. Off the gas all vents work fine.
Old 10-09-2015, 01:55 PM
F350GK
F350GK is offline
Hmmm
I unhooked the line completely and now it works perfectly..,,,????
Old 10-10-2015, 12:42 AM
choate's Avatar
choate
choate is offline
I have,a different problem with the temp **** but yeah I just tore all the white line out of my truck too. I can't remember if I put silicone on the ends or not but my vents work fine.
Old 10-10-2015, 04:18 PM
F350GK
F350GK is offline
choate; you just pulled the lines and plugged the ends of where they led? Or did you patch and replace your lines? I've now driven about 200 miles with mine unhooked and all systems work fine.
I'm afraid that maybe this controls something else too that I'm not aware of and could accidentally harm.
Old 10-12-2015, 03:29 PM
choate's Avatar
choate
choate is offline
I don't think you are going to harm anything. I can't remember or not if I plugged them but I know I looked at that white line you have in the picture and I squeezed it because it looked like it was deteriorating and it basically fell apart in my fingers. Broke in half. Didn't notice any changes after that but I didn't know what it was. I thought maybe it was something the PO used to hold wires together or something not part of the actual system.
Old 10-13-2015, 05:34 PM
choate's Avatar
choate
choate is offline
Don't notice any difference but I did fix mine today. Here is what you need. Fits perfect
Varro
17
11-29-2017 03:01 PM
azul_grande
06-15-2017 10:58 AM
pcdocta
43
03-19-2017 05:16 PM
46Whizzer
05-12-2016 04:41 PM
Odisvan
1968-2013 Full Size Vans
12-12-2015 10:42 AM
Quick Reply: AC/Vents opening/closing on their own
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
