1989 F150 351W FI, need vacuum diagrams/pictures please
Hi guys and gals,
I've got a new toy, an 89 F150 with the 351W, FI. I'm having a lot of trouble getting good diagrams for the vacuum routing, and i've still got some questions left.
Ideally, someone with the same engine/configuration could post a picture of their correctly working setup, and I can just copy that.
Specific current questions:
The "Coffee can" on the passenger side wheelwell is a vacuum reservoir can, and that's supposed to keep the HVAC system from losing vacuum under heavy engine load, right?
The small box protruding from the A/C and Heater area in the back passenger corner of the engine compartment; what is it for, and where is the vacuum line from it supposed to connect to?
Thanks!
I've seen that thread before, and while it's got a lot of useful information, it doesn't cover some of the pressing questions I have.
Let's start with this one:
The small box on the outside of the HVAC box in the back passenger corner; mine has a vacuum nipple, but isn't connected to anything, and I can't figure out where it's supposed to connect to. I also have very little heat coming out, but my radiator is full, and everything else HVAC wise works correctly.
That link is also wrong. The blender door is cable controlled and not vacuum controlled.
Also the blender door is 100% inside the cab and no part of it is inside the engine compartment.
That diagram is for the emissions system only.
New news!
So, I installed a motorcraft YG193 vacuum valve that I found on Amazon ( ), as shown in the pictures below. So far, no difference, but i'm waiting to test the A/C under load. I still don't have much heat coming out, and now I see that when I move the selector from hot to cold, the vacuum operated damper motor, located on the shroud at the passenger firewall, doesn't move, which I expected it to.
Thanks to a recent blowout on the front right wheel, I have some new damage to the blower motor shroud, so i'll be working on that next.
My next round of questions for you:
1)What else could I be checking to determine why i'm able to get great A/C, but really poor heat on any setting (vent, floor, defrost)?
