92 f150 5.0 front tank problems?
ok guys,
got a 92 f150 5.0L with dual tanks
we was told that the front tank dose not work.
but the pump runs.
and will start on the front tank but there no gas in it.
can anyone tell me what to look for?
i did flip the switch to the front tank once and it die but only once.
but the pump runs.
ok guys,
but the pump runs.
but the pump runs.
I had the same problem, was told it was probably the rear module, and it made since, seeing as how the front pump sounded strong and I did have pressure, just low. After changing the rear assembly, it didn't fix it. Changed the front and problem solved. It is a guessing game. That's why the dealerships would only change them in pairs. If you have the bed off, you could try pulling the rear assembly up some and listen to see if fuel is pumping into the tank. I tried this but don't know if this works, since my rear module wasn't the problem.
Whiteboi27
16
03-09-2023 11:27 PM
banjobrad05
03-23-2016 02:48 PM
longpoleman
20
11-04-2008 03:20 PM
bdinger
16
02-05-2006 05:27 PM
