"SD bearing housing mod (Freakify Mod)
Ok so there is a problem with our turbos, biggest flaw, trying to take it out. So I read went thru forums but no one actually did it so given the opportunity of having all the necessary parts I said "Why not" , I also saw how redicilous the price on bellow up pipes were for our obs trucks I said something has to be done (at the time of my build I was short on funds so I worked with what I had with e99 stuff laying around so no bellows for me)
Another cool thing with this is we can retrofit sd bellow up pipes by simply getting a late sd turbo pedestal and driverside exhaust manifold, that way we can keep our turbo and intake manifolds
As you know you have to remove your turbo but ill skip this process since theres alot of threads regarding this.
Parts list are as follow:
-center bearing housing from any year super duty and bolts.
-E99 turbo pedestal and bolts (late 99 and up pedestal optional if you want bellow up pipes you will also need driverside exhaust manifold)
-Turbo rebuild kit (might as well its out and you need the backing plate seal)
Added info!!! Need an e99 backing plate.
And the most important The will to actually do it
-Step 1 (after you removed the turbo and pedestal) disasemble the turbo making sure the orientation in which you remove the parts
-Step 2 clean your turbo thrughly and the donated bearing housing and lubbing everything before the bearings and all the good stuff goes in(theres other threads regarding turbo rebuilds) now instead of the old cartridge going in you put the SD one in
-Step 3
Remove the pedestal and intall the "NEW" pedestal in simple as that
Step 4
Repeat the process of install of turbo wich you can find on other threads
Step 5
Crack open a beer and admire your work
Ps the ebpv might not work with the late 99 and up pedestall as the rod is shorter on the late 99.
-Step 3
Step 4
Step 5
Like mention on post one low on funds not even for the dormans, and I worked with what I had laying around. I made this simply to keep the stock turbo with the 1.15 housing. If I went the whole nine yards i would of had to put the .84 housing wich is No Bueno in my book
