So I have a 1978 f150 ranger 35s the front end has a sag too it or it was never lifted not really sure.. the question is I have some old 6 inch lift coil springs for a I beam 80-96 f150 I was wondering if anyone knew if they would fit on my 78
Thanks in advance
Steven
They'll fit, but you'll end up with a rough ride, they're a stiffer spring designed for the TTB front end because of the lever action of the beam. Solid axle springs are softer
It depends on how much yours has sagged. You can get springs for an A/C equipped truck and gain a bit of additional lift. I did that on my orange 78 in my Avatar. Don't remember however if the springs were done when I took that picture.
You can actually get a set of heavy duty springs for the front end that are a little stiffer. Cost less than $100 shipped from rockauto. (Last year they were)
