1951 F3 marmon herrington
#361
Did those pins snap off the upper and lower spindle caps? Very odd. And I have seen welding like that before. My f250 4x4 has a similar repair. My f250 also has similar damage inside the knuckle ball. I think your welds will survive in its new retired status. Unless its not retired.
#364
in near perfect condition so I don't think they are broken. I can't find anywhere they could go, there are no "pin holes" anywhere so I'm begining to think the bearing cups on the one axle that is welded on both sides is where they once went.
#366
Ouch. Am I seeing right that the inner bearing chewed on the case? If so, machine work ahead, and metal fragments everywhere. Guess the fragments got into the bearing and chewed it up. Chuck had to replace my rear axle housing because it was hurt, but I don't recall him saying there were heroic measures needed on my front. I think you're pulling the axle. Stu
#367
#372
I was looking to see if the yoke ears were broken or just cracked and found that the center ball bearing has a hole in it and the pins fit....the hole doesn't go all the way thru and the pins aren't long enough to extend past the ball anyway so....and that would still leave an extra pin 😵
Pin goes in nicely
This is the opposite end of the ball from the hole
Inside the steering knuckle, a little banged up but not too bad.
Pin goes in nicely
#374
I talked with Chuck yesterday and he confirmed that those pins are actually supposed to be one pin that goes thru the outer axle and into the hole in the center ball of the CV joint. Mystery solved, thanks Chuck!! He also said that those CV joints can be rebuilt but finding the right shop can be tricky and expensive and finding a doner truck might be a better option but also might be expensive. I'm going to explore the first option locally and see what I can find.
#375
Have you had the left side apart yet, or only the right? On my 1/2 Ton, the RH side was much worse than yours. The ***** had come out and caught between the joint and the inside of the knuckle, while the joint continued to turn. I was able to cobble mine together until I located a spare front end for needed parts. When these things are put back together, you need to get the center line of the inner and outer shafts to match as close as possible. This is adjusted with the shims that go between the pivot pins and the caps. I don't see any shims in your pictures. It also looks like your pivot bearings might have been replaced with bushings. The 1/2 Tons originally had ball bearings in those locations. Many were replaced by machining the recesses in the housings to accept tapered roller bearings. These bearings are pre-loaded a bit by adjusting the shims. I'm curious if yours might still have the original set-up on the other side? If it does, you can compare measurements to see if the repairs on the RH side may have caused misalignment between the shafts. That "grooved pin" in the joint area of the outer shaft is what holds the "center ball" pin in place, after the joint is assembled. If you have the manual, it should describe the disassembly and reassembly of the joint. Mine are worn enough that you don't have to take out the grooved pin to get the joints apart. When you get everything back together, be careful of making sharp turns while in 4WD "Positive" unless you're driving on loose surfaces. My steering gear gives about 4 full turns of the wheel from lock to lock. I play it safe and never turn the wheel more than 1-1/2 turns off center (either direction) when I have 4WD engaged - I learned that the hard way! My idea is, that the CV joint has to elongate a bit when you turn the wheel off center, and for that reason the center ball ideally would be located on the center line of the two pivot bearings. That bronze bushing in the axle housing has a flange, and it's normal to have some wear on it. However, the back side of the joint shouldn't be eating into the housing like that. Make sure the axle does not bind inside the knuckle as you pivot it through it's normal range of travel and across it's center (wheels straight ahead) position. Keep at it, I know you are going to get it shaped up and back together soon! I'll attach a few pictures of some 1/2 Ton parts. The shims in one of the pictures are not the correct ones for a M-H unit. Also, the exploded view of the Bendix joint is not M-H, but is very similar. - Bob
