1951 F3 marmon herrington
#271
on
I never measured them Stu. Even if they are out of spec I think I would run them "as is". There is no lip on the edge to speak of and no groves. Hard to believe from the looks of the old girl when I picked it up. My first guess is the front brakes stopped working years and years ago and were never fixed. And i never tried to seperate the drum and hub. When I do it will be on a bench with plenty of penetrant and hopefully patience. Note the big flat tip screw on the face holding the drum to hub. That will also need removed.
#272
The scenario you envision must have occurred on my first R32-4, the red ND truck. I took its welded axle (#342), its rear, the good VA donor axle (#544), and ND transfer case to Chuck to have him work his magic, install his 4.11/1 gear sets, etc. He found that the drums on #342 were amazingly within spec, the drums on #544 were junk, and the original rear axle (as we've swapped texts about) was itself fractured junk. He replaced both cases and half shafts from an early rear axle, and combined them with the 52 brakes. My AZ project truck has been assembled from nationwide donors. Stu
#273
#274
I've not measured one but bet McMaster-Carr can match them.
https://www.mcmaster.com/#flat-head-...crews/=16zc5e8
The F-2, 5700 gvwr, and F-3, 6800 gvwr, were combined in the R3-4 and R32-4 models. Marmon-Herrington upgraded the F-2 trucks to F-3 specs. One difference was special rear F-2 shock mounts having an upward offset versus stock F-2s that offset down. The F-3 got no rear shocks. The other difference is wheels. All F-2s I've seen have 16" singles (Budd 47210s). This has been a puzzle to me because the manuals don't agree with what was done in practice. Stu
Edit - just to show the pieces, here is Mark's F-2 with the upward offset rear shock mount.
Here is a stock F-2 set.
Budd 47210
Budd 47210
#275
Budd 47210
Budd 47210
#276
The point of which? The shock mount offset was to compensate for the spacers. Might have allowed stock shock absorbers to be fitted. On the wheel differences between the manual and real life practice I have no clue as to why. Stu
Edit - besides Mark's F-2, these two also have 47210s. I'll have to think on others. I don't recall whether Josh got wheels with his F-2. It was all apart when he got it. The other one I've seen in pics sold on eBay and had a mix of wheels. Stu
#277
#279
#280
#285
on
The more I look at these pics the more questions I have. I even went to the MH manual and could not find a diagram. These front hubs have ONE wheel bearing? That's all the manual talks about. That's all I see. And the big nut under the MH cap holds the entire hub into the spindle....that's obvious but just think about that. Another question is "what holds the axle into the differential"? The more I think on this the more confused I get. It seems like the axle should slide out of the diff/axle tube when the hub is removed. But what keeps it from sliding out with the hub attached to the end of the axle shaft?
Clear as mud right?
Clear as mud right?
