1951 F3 marmon herrington
#601
#602
I’ve used that stuff with decent results. Similar to your air cleaner, I have a galvanized bird bath that after a lot of years began to leak. Smeared that stuff on the bottom and it’s been fine. Also have used it to make new rear axle bump pads. They aren’t being repop’d, and Chuck says the NOS ones are gone. Took a mold of an old pad then poured that stuff into the mold. Takes a while to dry, and doesn’t release the molds too well, but does a decent job. Stu
#603
I've got a spare one of those air cleaners, but have never turned it over to look at the bottom - figured the oil would spill out. Never thought of water getting inside and the oil floating at the top - must have been what happened to yours? Now, I have to go out and take a look at it! Is there a thread that shows how to convert them to the paper element? - Bob
#604
#605
#606
Even though I had an F2 parts truck for several years, I never checked on the rear axle "bumpers" - just thought they would be the same as on my F1. I just looked in the Ford Parts Manual, and the F1's used pads with an early 40's car p/n - the larger pickup's p/n ('48'-'52) looks like it was first used on Model BB trucks in 1932. Are the axle bump stops on F2 and F3's mounted on extensions like these for the 1/2 ton's, which I've pictured below? Thanks! - Bob
#607
The 48-52 F-2/3 M-Hs have wooden extension blocks under the bumpers. I’ll take a close up picture of my Flexseal bumper and a block later and post a picture. The 53 and later M254s have metal extensions similar to your half ton picture. Stu
Edit: I can’t add today the pics of the lift block and my bump pad. I am answering the call of the wheel and tire Gods and won’t be home until the weekend. I will post the pics then. Stu
#608
#609
#610
#611
#612
On "old green" (actually what the kids call it) the axle starts to get near the bump stops with a load of about 3,000 lbs. So far haven't broken any spring leaves, but those loads pretty much reverse the arch in them. Do any of you "tire guys" recognize the tread on my spare? I'm pretty sure I remember these from the 50's when they were a popular snow tire choice - later they changed the tread design a bit, but still went by the same name. - Bob
#614
#615
