Pitman Arm helpppppppp (1977 f150)
Hello all, quick question..
I'm doing the 1977 to 1978 steering swap on my 77 f150, does anyone know if using a drop pitman arm on a stock truck will matter? It's pretty difficult to find those 1978 pitman arms (unless someone wants to sell me one)
-Bryan
-Bryan
No need to make another thread to just ask if someone has one for sale. Asking in this thread or in the WTB section would work the best.
WTB - Parts & other - Ford Truck Enthusiasts Forums
Hitting your local JY is not an option for you? Seems like a pretty common part in my local JY. If the truck is stock then get a stock pitman arm.
D7TZ-3590-C .. P/S Pitman Arm / Marked: D7TA-3590-GA / Obsolete
1977 F250 4WD from serial number Y20,001 (not a High Boy) / 1978/79 F150 4WD SUPER CAB / 1978/79 F250 4WD / 1979 F350 4WD
D8TZ-3590-B .. P/S Pitman Arm / Marked: D8TA-3590-BA / Obsolete
1978/79 F150 4WD REGULAR CAB & Bronco.
If the lift includes a longer frame mount for the track bar that drops the frame end ..... then you will need a drop pitman arm as well. This assumes you want good steering ..... which means the drag link and track bar need to be at the same angle as you want them to go through the same arcs as the suspension works.
The tart of a P.O. that I bought my 77 from basically just put the 4" lift on the truck and nothing else. Did not change the bushings the pitman arm, NOTHING ELSE!!! It was all over the place when I bought it. Now I put the 78 steering components, drop pitman & new rubber, can't tell you the difference its like new.
Justforfishing
20
04-07-2018 11:59 AM
yediford
09-01-2007 11:57 AM
