Loss of Power Towing 5th Toyhauler - Page 2 - Ford Truck Enthusiasts Forums
Go Back  Ford Truck Enthusiasts Forums > Diesel > 6.7L Power Stroke Diesel
Reload this Page >
Old 10-01-2015, 06:03 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.Big-Foot has a spectacular reputation.
Originally Posted by sdetweil View Post
you are quite the lucky one! don't change what you are doing
I don't try to beat them down out of most their profit...
I've also never been turned down on a warranty claim - even a car that was 5k and 3 months out of warranty...
Dealers remember how you treat them...
Old 10-01-2015, 06:35 PM
Karl4Cat's Avatar
Karl4Cat
Karl4Cat is offline
Karl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputationKarl4Cat has a superb reputation
I beat them down out of every last penny I can. Just like they are trying to do to me. I'll buy my own DEF...
Old 07-01-2017, 04:39 PM
glenngjl
glenngjl is offline
glenngjl is starting off with a positive reputation.
Power loss 6.7 while towing
I had the same loss of power pulling up a not so steep incline and a mountain pass. I felt a miss and sudden loss of power. Had to pull over to the side of the road as the truck would hardly pull itself. This happened three times in a row. No codes were set. Unhooked from trailer and truck ran great. Finally had to call for help and switch to another truck to finish trip. Put truck on a dyno and found no problems. Going to hook back up next week to take another try. Any ideas? 2011 F250 6.7
Old 07-01-2017, 04:41 PM
senix's Avatar
senix
senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I'd be looking at the HPFP if I were you. VCV might be an issue. Any codes?
Old 07-01-2017, 04:46 PM
brickman
brickman is offline
brickman is gaining momentum as a positive member of FTE.brickman is gaining momentum as a positive member of FTE.
Any kind of mods been done to it?
Old 07-01-2017, 04:48 PM
glenngjl
glenngjl is offline
Had two different shops look at problem, neither could pull any codes to find a problem. No modifications
Old 07-01-2017, 04:59 PM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
I'd be looking at two things -
1) Fuel filter
2) Restriction in the tank (a number of guys have found the cap seal from fuel additives stuck in the intake)
Dyno pulls will not pull the fuel the way that dragging a heavy trailer up a steep hill will and the dyno pulls are typically shorter in duration.
Old 07-01-2017, 05:08 PM
glenngjl
glenngjl is offline
Replaced both filters, did not fix problem.
Old 07-01-2017, 05:15 PM
senix's Avatar
senix
senix is offline
Do you use a fuel treatment in the fuel system?
Old 07-01-2017, 09:28 PM
glenngjl
glenngjl is offline
Had not added any fuel additives, but have since began to add, but have not tried to tow.
Old 07-02-2017, 07:21 AM
golfmedik's Avatar
golfmedik
golfmedik is offline
golfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputationgolfmedik has a superb reputation
Something is shutting it down but failing to record the event it sounds. I think a live data stream with the rig in tow is in order to find it.
Old 07-02-2017, 08:43 AM
HRTKD's Avatar
HRTKD
HRTKD is offline
HRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant futureHRTKD has a brilliant future
In my half ton truck, that symptom would point to a fuel pump or at the very least a fuel delivery issue. Why the fuel pump doesn't throw a code is beyond me.
  #28
Old 07-02-2017, 09:39 AM
Big-Foot's Avatar
Big-Foot
Big-Foot is offline
My thoughts exactly...
  #29
Old 07-02-2017, 10:22 AM
glenngjl
glenngjl is offline
Next weekend I'm going to hook up a scanner and take a drive with my son-in-law, who is a mechanic to see if we can find anything. Hopefully the scanner will find something.
  #30
Old 07-02-2017, 10:23 AM
senix's Avatar
senix
senix is offline
do you have a scanner that can read the ford specific codes?
Quick Reply: Loss of Power Towing 5th Toyhauler
Contact Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
