2004 V10 Wires / Coils - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 09-29-2015, 05:39 PM
glennemay's Avatar
glennemay glennemay is offline
glennemay is starting off with a positive reputation.
Hey all,
I am absolutely certain that this conversation has been had in the past. however I am wanting to get a current opinion.
My 04 V10 DRW F350 has a cold/wet weather intermittent skip. Not even enough to throw a code. However. Since I live in the northern snow belt I figure it is going to roll out on me about February and in the middle of the worst snowstorm of the year.
I am suspecting coil(s) or wires.
Do any of you have any suggestions on brands, better or worse? Should I just stick with the Motorcrafts since they seem to have held on for 200k?
G
Old 09-30-2015, 06:37 AM
ashleyroachclip ashleyroachclip is offline
ashleyroachclip is starting off with a positive reputation.
Sounds like bad boots.
Boot , spring kits are cheap, replace, and use generous amounts of dielectric grease .
Then check harness connectors.
Coils some times go bad, but not that often.
Old 09-30-2015, 08:27 AM
Bently_Coop's Avatar
Bently_Coop Bently_Coop is offline
Bently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputationBently_Coop has a superb reputation
Motorcraft is the preferred brand. As Ashley said above check the boots and springs.
When were the plugs changed last? Should be done every 100k at minimum. I would also recommend o-rings to help seal the plug wells. See link below for more regarding this.
https://www.ford-trucks.com/forums/1...l#post12821306
1977 ford f100 wiring problem christiansill5509 1973 - 1979 F-100 & Larger F-Series Trucks 5 02-05-2017 11:03 PM
carb problems.....??? Bills68F250 1967 - 1972 F-100 & Larger F-Series Trucks 19 09-28-2016 11:36 AM
Help with duraspark ignition Rulebreaker Electrical Systems/Wiring 32 09-25-2016 01:24 PM
any ideas appreciated thanks miller56 1973 - 1979 F-100 & Larger F-Series Trucks 2 03-08-2016 06:55 PM
EZ-21 installation question JimG1098 1948 - 1956 F1, F100 & Larger F-Series Trucks 12 12-29-2015 08:03 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
