Lets welcome our newest member, stpackard!
Hello all, Sam Packard here in Lincoln. I'm starting a 1969 F250 4wd project - step one was driving it from Joliet IL, getting a good tarp setup (last night's rain showed I'm going to need to build a tarp bed frame), and making some blocks for it. Truck is from Oregon and has minimal rust. Mechanicals are solid, now my long-term project is to tear it down, sand blast, undercoat, and repaint after raising our garage opening.
I look forward to checking out you guys' projects and posts here on this forum and learning some from you all.
Thanks
Sam Packard
Near South, Lincoln, NE
Seller's photo in Illinois
Rebuilt engine smells fresh after running for a an hour or so, Is this a 390
No choke plate but fires up (after getting out my wallet in Spring Valley Illinois for new battery terminals)
underneath cab. Truck is from Oregon. Was looking for minimal rust and solid mechanicals.
Fits in the driveway and my wife said she liked the truck
Before the trip home
Front end view
Thanks
Sam Packard
Front end view
Pat, I've spent the last few days looking through your project. It's inspiring to see your thoroughness!
Looking over your project, it looks like the big factor is the space, setup, tools, and time. I'd be a frazzled idiot to try to revamp my city garage and buy a bunch of tools all of sudden to get started.
My uncle has 4 70's f250's and the air, lift, and welding setup in his farm garage. He's restoring one with his son and I've got to get out there soon to check out the progress except that it's harvest time of the year. Thinking of trading some labor, I think I still don't mind wading in mud puddles! I'm wary of approaching even a family member: "Hey can I (we) tear down my 69 F250 in your shop and use your tools to restore it, and could you also lend some time and expertise? I have no idea how long this would take!" Not an easy thing for me to ask by any means!
I'm going to need to take it slow and continue keeping her dry while figuring out more about the whole seemingly complicated process of tear-down, body blasting, rust removal and parts patched, then undercoated and painted. Hopefully it's simpler than I think.
Ordered a set of shop manuals for the truck's year and if you can't tell yet, this probably screams that I'm a newcomer to auto mechanics! Not bothering buying/installing new door and window seals now even though it needs them. I'll do that when the final assembly happens and I'll make sure to not drive it in the rain or in the salt snow.
Thanks you all for the welcomes - this is a good thing going on - I look forward to reading more of you all's projects and seeing your builds!
Sam, the biggest thing is having a plan, and being organized. Bagging and tagging with lots of pics during teardown will keep you from going nuts putting it all back together!
Something else you may want to get, and it's only like 20-some bucks, is the parts breakdown CD for these trucks. Shows every single assembly, and how it breaks down, and all the part #'s. Trust me, its worth having! Here is a link to it if you'd like to order one:
1964-72 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
Was poking around at Watt's in Wymore and found these on a Ford van. They say Rotunda on them but have fomoco on the gaskets. It sounds like these might have been sold separately or are aftermarket. I think these look to be the western junior mirrors or a copy. They will need bracket work to install. Anyone know a glass place in Lincoln who could cut an automotive mirror to fit?
Perhaps they'll fit the 69 doors with some new stainless hardware and bracket work
Mirror design looks to be ford western but has rotunda on it
Larger gaskets say fomoco
Mechanic recommendations
Hi All,
I'm not a mechanic and tuning the engine is not something I have the confidence or know how to do right now. I believe the idle needs adjustment and it's been running a little rough at idle. Plus I'd like to get the piece of mind to know that timing and other things are tight.
I'd like to find a mechanic in Lincoln who'd know about this and who I could go back to for anything else on the truck.
Thanks in advance for any recommendations!
I appreciate it
Sam
I appreciate it
Sam
