300 with a c6 how do they run ?
#31
#32
Now if you had a highly modified 300 then it might be a different story. Or even a NP435 instead of the C6.
#34
The easiest OD unit for the NP435 would be the Advance Adapters Ranger torque splitter. It's a small gear box that goes between the bell housing and the transmission. This is the one unit I know of that can be used on a 2wd or 4x4 and be used while in 4wd. Most add on OD's can only be used while in 2wd. Not a big deal if you don't have a 4x4 truck.
The down side is it's a little over $1600. It moves your stock shifter back 7 1/2" and it adds another shifter coming up thru your floor( that wouldn't bother me but some people don't like it ) and will require driveshaft mods. It would work great with the NP435 because it would give you another gear between the 435's gears. Plus you get the OD. I want a couple of these bad. But they just aren't in my budget right now.
Here's a link to their website: Complete Units | Advance Adapters
The other choice is a aux. transmission like the Brownie box ( Spicer ). These are fairly large heavy 3 spd transmissions ( under, 1:1 and OD ) that remote mount between your transmission and rear diff. These were used in the old medium duty trucks I think from the 50's thru the 70's. These usually run $400-$1000 used.
I'm not all that familiar with the Doug Nash unit. But I don't think your OD unit could be used with the 435, without a bunch a fab work. Anything is possible with enough time or money thrown at it. It might be possible but is far from a bolt in deal.
#36
I loved my last 89 f-150 with 4.9/c-6 and 2.73 rear. put over 60k miles on it and beat the dog **** out of it off road constant neutral drops, fot on floor betyween reverse and drive. Put it this was i went thru 4 sets of motor mounts a steering gear box sector shaft snapped and fan went thru radiator 3 times. Yet i still daily drove it(can you say early 20's haha)
10 years late ri just bought its clone for DD duty, 89 f-150 4.9/c-6 with 2.73's. I love this combo...cheap simple and reliable, works great for about anything you want to haul in the bed, towing over 2k or so it struggles. But it does great on the highway at 55 or 75.
#37
I just got my truck back this morning from the c5 to c6 swap and initial response is that I regret the change. The c5 was substantially quicker than the 6. When rolling down the highway it feels about the same Quickness wasn't my reason for the swap but I miss the zip. It does feels stout under there now. Like it will outlive my grandkids and that was the purpose but It is now so sluggish off the line that I'm wondering if my Holley 390 needs to be retuned from a new starting point. Is it common to need a carb tune up after a swap?
#38
#39
Not sure but I'm certain that a new torque converter was installed. I can't find my receipt with the specs on it.
This setup does make running true duals with hedman headers difficult. I'm at my wit's end trying to get everything to sit without rattling off the crossmember.
I have photos of a guy who ran the hedman with true duals. I'll upload to google docs and post a link. He welded straps across the pipes to keep them from rattling. Me, I figure I'll get all the flow in the world with the 3" pipe, without the rattle or space constraint, and without having to install an X or H pipe. kevin. Good luck.
#40
I have a pair of exhaust clamps welded 1" apart to a piece of bar stock, think old timey handcuffs. Have it wedged in there so that the tension from the one pipe holds up the other. It's a Chinese finger trap for sure. My next best option, as I suspected, is to make a 90° turn before the trans with one of the pipes.
On a side note for you , when I had my headers off a few months back I sanded down, painted and wrapped them things in Lava wrap. I know they will rot out faster but the engine bay is significantly cooler I don't instantly blister my hands when tinkering around hot pipes. The heat transfer to the cab is also greatly reduced. Plus I think k it looks cool. Practical,probably not.
#41
Another member posted these photos, but I don't think he'll mind if I link to them because it might help you. https://drive.google.com/file/d/1lEj...ew?usp=sharing
https://drive.google.com/file/d/1Qr2...ew?usp=sharing
You can see it is very tight under there. That's why I elected to go with the one 3" pipe to the rear axle, and then drop down, once the gasses have cooled a bit, to a 2.5" tail pipe. The photos are of a truck with a ZF trans, which might be narrower than a c6? Good luck. Kevin
truckerboy
03-20-2010 07:27 PM
flcracker9
09-04-2007 12:18 PM
lrd56
08-12-2004 09:15 AM
