44ttb 8lug gears/parts truck question
im looking at getting a parts truck that has 4.10 gears and my truck has 3.55.
Is it correct to think that the front will just be a third member swap? And for the rear I have new brakes on my Dana 60, should I have the ring and pinion swapped over or just swap my brakes? And swap axles?
Also is a 84 f250 with no motor and a 5" lift with a decent body worth? I can upload pics shortly
Your truck is a f250? The front should be just a pumpkin swap, though you will pretty much have to tear it down to it. You have to pull the axles out of the front.
For the rear I would try to swap the whole axle. You will have to figure out what axle you have in your truck, and what's in the donor truck if you want to swap gears, and then you will have to get the gears setup. The picture above looks like a regular f250 and not a 250HD. I don't see the snoot sticking out of the rear wheel like a f250hd has. Does your truck have the HD axle in it?
Yes I have a heavy half, or the little f250. We both should have Dana 60 rears. Mine is for sure. And I don't recall another 8lug rear.
The from would be a third member, or a 9" housing swap right? Pull the axles out and drop the center with all the gears/pinion/such attached and the replace and put together?
What do you think that truck is worth? Has everything but motor and dash.
Dana rearends don't have drop out pumpkins like the 9 inch. You have to tear them all apart and swap the gears and reset everything. That's why if you can, and the 4.10 center looks good, I would swap the whole housing and then put your new brake stuff on the 4.10 housing. If the 4.10 center looks good, that would be a do it yourself project.
Scrap metal prices are down now, but you have to consider that. He probably could get $250-$300 for it at the scrap metal place, so I would start there.
redxl1664
11-30-2017 09:11 PM
