Facts About the TorqShift-G in the 2017 Ford F-250 Super Duty
#31
I'm with you! Though I don't have an EcoBoost, I've heard the proponents just like you talk about how it tows like a diesel without all the diesel drawbacks. That's what I'm looking for in my next truck. The main negative I have heard is fuel economy while towing. I'm not too concerned since my 6.4L gets 8.5-10.5 towing our fiver depending on how fast I drive and how hilly it is. I wouldn't see an EB being much worse on a cost/mile basis since diesel is running higher than gasoline.
#32
#33
The small EB from the F150 could go in it, or the diesel from the Transit. Shoot put the 2.0 Duratec in it, it's about the same lawn mower motor the Ranger had with the 2.3L I4.
I'm less worried about diesel-vs-gas than straight up no entry in the entire market segment.
#34
#35
I couldn't remember if it was 7 lugs or 8 but a pretty stout truck for a half ton package.
Supposedly Ford and the UAW are in negotiations right now to convert the plant that assembles the Focus and it's Hybrid cousin to the Global Ranger assembly plant. Maybe Ford will hear the call and bring a small diesel with it.
I love my ecoboost and likely wouldn't trade it for any engine that I've ever owned in the past. It pulls hard like a diesel with gasoline maintenance, win-win. Not everyone is is as convinced as me that it's the answer.
I'm still kinda surprised Ford is sticking with the 6R100/6R140-G for the Super Duty trucks rather than going for the all new 10 speed auto. Probably to keep with what they have proven to be reliable in the last 4-5 years rather than something new and unproven. Or maybe they did it because it can't handle the power of the PowerStroke or take the amount of work required by these trucks. Unless they have something in the pipe-line for 2020 or so.
#36
The Expedition got the 6R80 in 2007, and it's cousin the F150 continued on with the old 4R75E until 2009. Chrysler is moving towards the 8-speed transmission in their rear-wheel drive platforms, but that first started with the V6 models in 2013. A year later the V8 models got it, but as of now the brand-new HD models still have 6-speed boxes.
GM has a new 8L90 going in their half-ton trucks, but their HD models are still using the relatively ancient 6.0/6-speed combo.
In recent years powertrain failures seem to be downright rare. When's the last time anyone has heard of a truck being worked so hard that it blew up when all of the accessory systems were functioning as designed? I think manufacturers tend to be cautious when introducing new designs to platforms that have a higher duty cycle. Consider the 6.2 for example. Not a bad engine by any stretch, but stone-age simple compared to the lighter duty powertrains in the F150.
I think heavy duty pickups will move forward, but at a slower pace.
#37
#39
I know this is 6 months old, but hardly anyone talks about this or blew it off. Automakers to gearheads: Stop repairing cars
#40
The idea of removing emissions equipment is very enticing, but not a reality for many folks on this boat. As a guy in the military, I'd be a downright idiot to remove the emissions gear on a truck under warranty because my future living location is not up to me. Just because I live in NV today, doesn't mean I won't be living in Washington DC next month or Kommiefornia the next year.
That's not a gamble many of us can take.
#43
I think that part makes sense, Ford and other manufacturers seem to have done the same for the last decade with the exception of the 5R110.
#44
I have a fleet of them, 12's and 13's, 6.2L/TorqShift/3.77 rear ends. We find this combination is slow to upshift, slow to downshift, and tends to pause between gears. 'Clunky' is the best way to describe them. I suspect part of the problem is inertia in the gear train, all those heavy components designed for the 6.7L Powerstroke are just slow to react at times. It would probably be better if we had ordered the trucks with 4.30 gears, at least that way the engine would be deeper into it's powerband (6.2L's aint much at low r.p.m.'s). Not really a surprise, but the TorqShift is great behind the Powerstroke. To date we have had no TorqShift failures in any of our units. Just by virtue of the fact Ford has decided to change the transmission in 6.2L F-250's suggests there is an issue, the new transmission is probably better suited for the application. I think the TorqShift is still used behind the 6.2L in F-350's, isn't it?
#45
The 6.2 so far has not gotten a fair shake. It is a very stout and durable motor. However, Ford hobbled the output very early on to protect the diesel, and then never corrected that as the diesel gained power. They even crippled accelerator response by not allowing WOT until 3,000+ rpm. This engine could produce much more power if Ford wanted. It will probably never produce a ton of low end torque due to being quite oversquare but is a very good motor for the SD. Even at 385/405 rating it feels strong and sounds great.
