What do you think of the Crown vic install?
Old 09-24-2015, 08:09 PM
billys90's Avatar
billys90
billys90 is offline
I found these pictures on Craigslist. What do you think of the Crown Vic front suspension being installed like this? Would there be any safety concerns with this install vs the drilling through top and bottom part of the frame rails?
I like it, but I would still box the frame and add some gussets to the ears that replaced the top bracket from the CV.
Old 09-24-2015, 08:22 PM
HIO Silver's Avatar
HIO Silver
HIO Silver is offline
The installation above is half-azzed... no bolt sleeves, boxing, etc.
Boxing the frame is required... the top side of the CV subframe needs spacers anyways.
Crown Victoria/IFS Subframe Retrofit
FTE Thread: davewild's '78 F150
FTE Thread: elgemcdlf's '70 F100 CV IFS & MN-12 IRS
Fordification Thread: Crown Vic in a '71 F100
Fordification Thread: JG_F100's '72 LWB to SWB Conversion & CV Retrofit
FTE Thread: CarCrafter's 67 F100
FTE Thread: RockntheHawk's 77 F100
Old 09-25-2015, 09:22 AM
4x4slik's Avatar
4x4slik
4x4slik is offline
That is the difference Hio, they removed that top mounting bracket, it is only bolt to the frame at the bottom.
My concern would be stress on the aluminum from not having that top mounting point. I couldn't see were those stamped metal plates were on the truck. I would let someone else test it for a while before I took a chance of my front end breaking.
Old 09-25-2015, 09:28 AM
4x4slik's Avatar
4x4slik
4x4slik is offline
look what I found, Looks like a similar setup, makes a little more sense and eases some of my worry.
Found on this site by the way. https://www.ford-trucks.com/g/album/871300
Last edited by 4x4slik; 09-25-2015 at 09:29 AM. Reason: added location of original post
Old 09-25-2015, 09:33 AM
4x4slik's Avatar
4x4slik
4x4slik is offline
spacemarine83
13
12-28-2023 09:43 PM
Brown Falcon
46
12-22-2011 10:11 PM
Hamburgerfella
53
12-26-2010 08:03 AM
52'F-3
08-13-2008 06:56 AM
darkman
03-08-2005 10:40 PM
Quick Reply: What do you think of the Crown vic install?
