problem
Old Sep 24, 2015 | 06:43 PM
Fennil's Avatar
Fennil
problem
well i been having problems starting my truck 1988 f150 302 automatic c6 transmission, been starting with screwdriver across starter solenoid.
decided to try reading codes by jumping it, im not sure if i caught it right or not cus i saw it as 22, 12, 2, if anyone could help me that'd be awesome, i also have a neutral safety switch ordered from oreillys to install tomorrow, all other starting components are new or check out ok*battery and alt good*
Old Sep 24, 2015 | 07:05 PM
88XLTLariat's Avatar
88XLTLariat
https://www.ford-trucks.com/forums/1...de-lookup.html
Old Sep 25, 2015 | 07:39 AM
My4Fordtrucks's Avatar
My4Fordtrucks
EEC-IV code readers are pretty cheap so I stopped trying to count the flashing light a while ago.
Have you tried starting the truck in neutral or in other gears? Does it start or not? Have you tried jumping the switch? Just curious how you came up with a faulty NSS and not the starter solenoid or the trans linkage or ignition switch being out of adjustment.
The_underclassman
Jan 29, 2010 09:43 PM
Littlejon
Oct 16, 2009 07:29 AM
mememe
Feb 28, 2008 06:33 AM
birddog55
Mar 14, 2006 10:33 PM
beastybronco
1978 - 1996 Big Bronco
Aug 6, 2004 11:06 AM
