2000 Navigator Air Suspension Issue
I was wanting to know how the air system levels out the rear end. The driver side always sits about an inch lower than the passenger and i only see 1 level sensor at the middle of the axle. so is there another air valve that assures the solenoids are provided with a equal volume of air or could my drivers solenoid be weak? I have new airbags with new solenoid o rings and no leaks at the bags or solenoids
thanks
thanks
Also, if you'd rather try and replace just the O-rings first before spending anywhere from $25-$75 on a new solenoid valve then read here: https://www.ford-trucks.com/forums/1...orner-low.html
audichopper
1997-2006 Expedition & Navigator
15
06-12-2017 10:03 AM
alloro
04-28-2015 09:59 AM
