5 speed m5od-r-2
5 speed m5od-r-2
I have had it with the ford aod auto. trans.
I have a 1989 ford e-150 econoline van that I plan to install a m5od-r2 in place of the old factory installed aod.
I have a couple of questions ;
I hope someone will know the answers !
will the m5od-r2 bolt up to my 302 ?
are the m5od-r2 transmissions bolt patters the same for the 302 & the 6 cylinder engines ?
any info on the installation of the m5od-r2 in a 1989 van with the 302 5.0 engine ?
really need any info on the above subject .
thanks !!
thanks !!
The bolt pattern for the 300ci (4.9), the 302ci (5.0), and the 351ci Windsor (5.8) are all the same. I would really like to get my hands on one of those M50's myself. I got real sick of the C6 automatic and tossed it 16 years ago for a Tremec SROD 4-speed O.D. and did the total conversion myself. It's a very viable automatic to manual conversion and the 3rd generation vans (1975 to 1991) are the ONLY ones where such a conversion is do-able. All you really need are the coveted, hard to find manual linkage pedals and/or hydraulics and you got it made. It's a total bolt in operation. Having done this, I would be glad to share any and all aspects of this fabulous option on these vans.
NO MORE ELECTRONICS !
I am removing all of the electronic crap from this 1989 ford van, I have just bought a new factory ford wiring diagram & plan to remove all of the wiring &replace it with new...............
the main reason for this is ti revert to a carb-& pertronics distributor-coil.
I`m very tired of my distributor module going out in the middle of the freeway out of the blue.
this van to me is like a garage find hot rod............. so I WILL REWIRE IT TOTALLY WITH EARLY MODEL TYPE WIRING .
VAN CONVERSION & new ford factory 1989 e-150 wiring dia.
yea............... the aod has got to go.
I plan to put a M5R2 in my van............ I wonder if the cross member I have will work ?
will I need to just drill some new holes to bolt it up ?
if that is all for the cross member then I got it made jack !
I knew I would have to have the drive shaft cut & re-welded.
I have an aluminum drive shaft ...... maybe I should change that to steel ?
I plan to get a proper fitting drive shaft that is made for the M5R2 & fit the 3rd. member u-joint end up to the other shaft...... or vise-versa on the aluminum drive shaft, either one will require the correct yoke to work, after that viola ! I`m on the road again...................
Kj.keiscome
25
05-01-2018 11:52 AM
Babin
04-07-2009 12:17 AM
Joe7qb
06-02-2006 12:08 PM
mjb1962
01-03-2003 11:23 PM
canuck
01-21-2001 08:09 PM
