Pulled a P170 on nearly new 2015 6.7L
CEL today and pulled the bank 1 fuel trim code P170. Anyone else had this happen? 4500 miles and it did a regen within the prior half hour to hour. No other issues with driveability. Thinking maybe a sensor is acting up, searching google looks like an odd trouble code for a stock low mileage truck. Need the truck next week so not sure if it will go into shop first thing or not if it isn't a "dangerous" code. Since it didn't go into limp mode I am not as concerned but don't want to cause further damage and be liable either.
This is what I came up with. I think the code is P0170. Lifted from the Motorcraft OBDII for 2015
http://www.motorcraftservice.com/vdi...DOBDSM1501.pdf
FORD MOTOR COMPANY REVISION DATE: DECEMBER 22, 201
4 09.01.00.02-PAGE 36 OF 186
Fuel Mass Observer (Global Fuel Bias):
Fuel Mass Observer (FMO) is an algorithm used to detect deviations in performance of all injectors from nominal. The oxygen percentage as measured by the tailpipe oxygen sensor is compared to a modeled oxygen percentage based upon current fuel, boost, and EGR settings. Deviation between the observed and modeled oxygen percentage is expressed in terms of the error in fueling required to explain the deviation. This calculated error in fueling is then divided by the current requested fueling level to generate a ratio of percentage error in fueling. This fueling ratio is then filtered over time. If the filtered error in fueling ratio exceeds minimum or maximum limits, then a code is set.
Fuel Mass Observer (FMO) Monitor Operation:
DTCs P0170 – Fuel Trim (Bank 1)
High_HP
09-08-2009 08:52 AM
