ECU/PCM cause 4x4 to not engage?
Old 09-18-2015, 10:51 AM
Ford army 86's Avatar
Ford army 86
Ford army 86 is offline
Hey everybody, I got this issue with my 2006 F-150 where the 4x4 won't engage. Other than that runs fine. Troubleshooting everything from the vacuum lines to the t-case shift motor and only thing left is the PCM. Could just a small part of the ECU/PCM go out and cause just that problem?
Old 09-18-2015, 12:43 PM
projectSHO89's Avatar
projectSHO89
projectSHO89 is online now
The PCM controls the 4WD system so it's certainly possible.
I'd recommend exhausting all the procedures in the workshop manual pinpoint tests before condemning the PCM, though, as its replacement will put you into a shop to re-program the PATS system.
Old 09-18-2015, 01:29 PM
Ford army 86
So it's not just a (plug and play)?
Old 09-18-2015, 01:58 PM
projectSHO89
Nope. Hasn't been since 1998, last year for non-PATS, for the F150.
Motohead911
06-08-2019 05:45 PM
wtroger
2004 - 2008 F150
09-08-2018 11:34 PM
CREECY Strokin It!
04-05-2011 03:28 PM
rosco_p_coltrane
02-27-2006 09:34 PM
Quick Reply: ECU/PCM cause 4x4 to not engage?
