E4OD problems!!!
Old Sep 16, 2015 | 12:14 PM
Fazio's Avatar
Fazio
E4OD problems!!!
Hey guys. Seems to be the most knowledgable folks here. I could sure use your help. As title says I got stuck in some soft mud up to my rear bumper. I shut truck off immediately and got pulled out. (I work at a mine site, was not intentionally mudding) A day later it stalls when stopping at red lights and when I put into drive. I've changed the fluid and filter. Filter came out w pan. I have since then order a clip for filter. Also found the shift connector on the passenger side of the trans had all the wires stripped and the plug was full of oil from a leaky oil pan. I have also ordered a new harness to replace that part and have cleaned the plug w electronic cleaner. But I don't think that will completely fix my problem. That harness needed to be repaired regardless!
I have a 95 f150 w a E4OD trans and i-6
801anderson
May 24, 2023 02:13 PM
zottyzot
Nov 15, 2012 12:40 PM
UNTAMND
Feb 9, 2010 04:03 AM
WillieWeed
Jun 22, 2008 06:09 PM
P37-007
Apr 2, 2003 02:11 PM
