Tire size and GPS - Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8
Tire size and GPS
Old 09-14-2015, 08:21 PM
willtim1234
willtim1234 is offline
willtim1234 is starting off with a positive reputation.
Tire size and GPS
Please explain to me how changing tire size affects GPS accuracy. I have a 2013 F350 with Ford navigation/SYNC. I recently bought new tires, went from 275 to 295 ( about an inch difference ). My GPS was way off and at times appeared lost. Someone suggested disconnecting the battery for 20 minutes so the PCM could "relearn". This seems to have fixed the problem. I can put any Garmin in any vehicle and it can give me directions anywhere. Makes no sense.
Old 09-15-2015, 06:51 PM
willtim1234
Am I the only one that had this problem?
Old 09-15-2015, 07:42 PM
fishbones182's Avatar
fishbones182
fishbones182 is offline
fishbones182 is gaining momentum as a positive member of FTE.fishbones182 is gaining momentum as a positive member of FTE.
Tire size and GPS
No several have had the issue. It's something to do with the computer and tire size. You'll find the issue frequently in the f150 section. The Garmin gives directions based on the location of the unit and is not calibrated to the truck like the factory head unit is. Heck in order to swap your head unit in your truck to another factory one the vin has to be programmed otherwise it's nonfunctional
Old 09-16-2015, 05:04 PM
willtim1234
Thanks, Fish.
Old 09-16-2015, 05:49 PM
fishbones182
Tire size and GPS
Your welcome
Old 09-18-2015, 08:39 AM
Hotrod70d's Avatar
Hotrod70d
Hotrod70d is offline
Hotrod70d is starting off with a positive reputation.
Since going to larger tires my speedometer is more on with my gps. Almost as if the factory is programmed for 20 inch rims and the 34 inch tires from the factory. I had 275s 18 inch tires now have 35 inch tires on 18
Old 09-20-2015, 06:34 AM
Pit Crew's Avatar
Pit Crew
Pit Crew is offline
Pit Crew has a good reputation on FTE.Pit Crew has a good reputation on FTE.
My 2014 xl is off about 4mph according to my Tom Tom. Maybe I need to put bigger tires on it.
Old 09-20-2015, 12:31 PM
fishbones182
Tire size and GPS
I think the input a tire size into the computer and not revs per mile or they just use a happy medium that's close enough. Different tire manufactures could have the same size but could differ in overall tire height and width which would cause it to be off.
Bigdon68
Fifth Wheel & Gooseneck RV Towing
05-03-2017 08:53 PM
coolguy1419
Crossovers
08-18-2016 01:38 PM
mtnxtreme
2009 - 2014 F150
25
02-29-2016 09:32 PM
Turbo Dog
2009 - 2014 F150
52
02-18-2016 06:04 PM
Ryan Gorissen
09-16-2015 08:57 PM
Quick Reply: Tire size and GPS
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
