Low power/ surging
Old Sep 14, 2015 | 09:28 AM
bcarless's Avatar
bcarless
Low power/ surging
I have a late '99. It's been weak all summer. Took it to the dealership. They put it on the computer and said the only problem was bad injectors. Specifically #8. I replaced them all. It's still weak and now is starting to surge going down the road. I have my suspicions but I'm not a mechanic. Please give me done ideas. Thanks.
Old Sep 14, 2015 | 09:40 AM
bcarless's Avatar
bcarless
The truck is stock. I changed the air and fuel filters a couple moths ago.
jhl3's Avatar
jhl3
What is your oil level, fuel level, fuel pressure, ICP? Have you ever changed your CPS? Look for chaffing under the wiring on the drivers side wiring harness over the valve cover. Check the tin nut on the back of the IPR.
What are your suspicions.
Old Sep 14, 2015 | 10:20 AM
bcarless's Avatar
bcarless
Acts the same regardless of fuel level. Oil is good. CPA was changed this spring. What should it look/do to the icp? Fuel pressure was checked at the dealer, 58 no load.
Old Sep 14, 2015 | 08:22 PM
bcarless's Avatar
bcarless
CPA=CPS, damn spell check.
Here's what it does. I pull up to a stop sign, hit the throttle, nothin'. Takes a few seconds to respond. Then slowly starts to move. No SES light. When under a load, weather pulling a trailer or going up a hill, it chugs/surges a little bit. Could this be a CPS or TPS issue? Time for the hutch mod?
Old Sep 15, 2015 | 09:10 AM
bcarless's Avatar
bcarless
Help help help
Old Sep 15, 2015 | 12:12 PM
DND58's Avatar
DND58
If you use cruise control under same conditions, does it chug or surge?
You can try unplugging the ICP connector on drivers side head. Look for wet/oil in connector. Try driving this way, disconnected. It will trip a check engine light, but see if any different performance.
Old Sep 15, 2015 | 12:32 PM
bcarless's Avatar
bcarless
I'll try cruise control tonight. I have a short commute on dirt roads to work. So a hardly use it. I'll try unplugging the ICP.
Old Sep 15, 2015 | 12:58 PM
jhl3's Avatar
jhl3
ICP=Injection Control Pressure-which DND58 advised you to unplug the sensor for.
When is the last time that you changed your fuel filter? What color was it when you changed it?
Old Sep 15, 2015 | 01:00 PM
clem1226's Avatar
clem1226
That's a pretty much worthless test for your symptoms. You need fuel pressure under load.
It sounds like possible fuel starvation to me. Clogged pickup in the tank, fuel pump pre strainer you didn't know was there from previous owner etc.
Old Sep 15, 2015 | 02:20 PM
Bonanza35's Avatar
Bonanza35
Fuel pressure under load is important, I'd make something up to check. Sounds like TPS from a stop sign but other tests should be done first. Also have you checked your EBPV, Is it partly closed? If fuel pressure is low under load I'd drop the tank and do the mods, then change the lines and pump if need be.
Old Sep 15, 2015 | 08:11 PM
bcarless's Avatar
bcarless
I disconnected the ICP and it ran better. I used the cruise control and didn't notice anything unusual. What should I do with the ebpv?
Old Sep 15, 2015 | 08:20 PM
jhl3's Avatar
jhl3
OK, was there oil in the connector? EBPV=You want to make sure that it is open fully
Old Sep 15, 2015 | 08:47 PM
bcarless's Avatar
bcarless
I'll look for oil in the morning. Where is the EBPV?
Old Sep 15, 2015 | 08:53 PM
jhl3's Avatar
jhl3
Hope this helps...
