Industrial Injection Reman injectors.
I am not sure who is best to get your injectors from, but i found these injectors on the internet. Thought they may be worth looking into. They are 120CC, and they claim 60HP overstock. I am running a stock truck other than the TS 6 position. I will send the chip back to have it reburned if I go this rout.
I plan to upgrade the turbo to stage I, do up pipes, down pipe, HPOP, IDM and an inter-cooler. Just waiting on that stuff untill later as the 4x4 DRW conversion, new injectors, IPR, and H1 wheels and tires are racking up quick.
My question is if you think these injectors would be a good rout to go or not.
Here is a link to the injectors:
Industrial Injection "Reman" 7.3L Powerstroke Injectors
Most around here go with Jim at rose wood diesel. When it comes to injectors you have to know your stuff or you won't be happy with the results.
Rosewood Diesel Shop
Received 3,107 Likes
on
Thats the problem when you ddon't research enough.... Thats why I try to research it to death before I pull the trigger
Stage 1 from jim at Rosewood, you wont be dissapointed. I have them and world of difference from the stock 90cc to the ab injectors I had before. All with custom tunes. ( my bad the tunes were on my friends old truck. My truck was running the ab' with canned tunes) brain fart. But like mention above you will be satisfy with the end results
