352 manifold gasket question
bphirt1,
Do you have a photo, manufacturer name and/or part number of what 'metal heat shield' it is that you bought? If so, please share it, as I do not have any idea of what it is you're referring to......i know header flange to cylinder head gaskets, I know header collector gaskets, I don't know 'metal heat shield'.
BarnieTrk
BarnieTrk
bphirt1,
C1SZ-9448-F .. Right Heat Shield / C1SZ-9448-E .. Left Heat Shield
1961/67 F100/350 352 / 1968/76 F100/350 360/390 / Misc: 1961/71 FoMoCo FE Passenger Cars.
Ahh, yes, I remember them now.
Now as I recall, there are some aftermarket styles that are thin steel types and sandwich between the manifold and the cylinder head and have a small 'flange' at the top to protect the wiring, whereas the OE style heat shield bolted on to the OUTSIDE of the manifolds, again to hold/prevent the wires from resting/touching the exhaust manifolds.
As The Masked Rider indicated, typically header manufacturers do not say much, if anything, about installing the heat shields with their product.
There are many opinions on what is the best way to install headers, including NOT to install them. A quick search on the FTE forum will give you much to read on the subject.
Based on my experience, I would closely inspect your cylinder head sealing surface looking for serious pitting or burned gouging on the sealing surfaces. If you have any significant pitting, it would be best to have the heads re-surfaced. For a low-budget repair, I would first recommend you try using some good-quality, high-temp sealer and a set of quality exhaust gaskets and new header bolts. Make sure the cylinder head surface is as clean as possible and run a oil-lubed tap or new Grade-8 bolt in & out of all the bolts holes to clean the holes of any rust. With a smear of sealant on the cylinder side of the gasket and some nickel never-seize on the new bolts, install the gaskets & torque the new bolts in a similar manner you would the OE manifold; top inside, lower inside working your way to both ends. Once installed, allow the sealer to cure overnight. When you start the engine, don't rev it, let it idle for ten minutes, letting the engine warm fully, then shut the engine off and allow it to cool. Once cool, re-torque the header bolts in sequence again. For the next two outings, drive it normally - no high revs, then once its cool, re-torque the bolts again. Now, hopefully, the leaks will be sealed for a while.
Ensure you've tied your spark plug wires back in a fashion to keep them from being within an inch of the headers or they may melt or burn if allowed to even touch the header pipes. I would also suggest you consider installing some sort of a head shield to protect your starter from the higher heat it will receive since the headers will be radiate much more heat than the cast-iron manifolds ever did. Also ensure the heavy-gauge wire running to the starter can not touch a header pipe. I used some aluminum foil tape on the wire, which provides some heat protection.
Good luck! -- BarnieTrk
Now as I recall, there are some aftermarket styles (same as factory installed) that are thin steel types and sandwich between the manifold and the cylinder head and have a small 'flange' at the top to protect the wiring.
Whereas the OE style heat shield bolted on to the OUTSIDE (what in the world!?) of the manifolds, again to hold/prevent the wires from resting/touching the exhaust manifolds.
I've never heard of or have seen any such thing!
FE valve covers have tabs on them for B8Q-12297-A wire separators, these slip onto the tabs, retain the wires in place.
B6A-12297-A wire separators were used on the wires before they reached the valve covers.
Pic from 1949/59 car parts catalog showing these parts.
The factory heat shields.... do not bolt to the outside of the manifolds. I've never heard of or have seen any such thing!
This is similar to what I was thinking of:
Ford FE Big Block Heat Shield for 352 360 390 428 See Various Apps 4440 | eBay
I'm not recalling exactly what FoMoCo called this part, maybe not a heat shield, maybe a 'heat stove' or 'heat riser' or something like that...
BarnieTrk
Bill,
asidpara
03-05-2012 07:00 PM
ford66
08-17-2009 08:09 PM
buckrogers
12-05-2008 11:36 AM
gregg_a_g
02-26-2007 05:45 PM
