I have a 2014 Super Duty F250 that the factory satellite antenna is loose and i can hear the air when inside the cab. How do i tighten or remove it. Do i have to pull down the head top and visor to access screws underneath it? Does it just pop off the roof? Is there a cap covering the antenna to access the screws?
I had to get my clearance lights fixed. They had to take the headliner down. My guess would be the same is true for the sat antenna. It took the dealer less than an hour to change out my light bases. One advantage to having the dealer do the work is if you have the same problem again, out of warranty they will fix it under warranty.
