Motor mounts for 1972 LN-9000 with Detroit Diesel 6-71
Hi,
I am assisting in the overhaul of my family’s dump truck. We are overhauling the engine and would like to replace the motor mounts (I am referring to the rubber mounts/isolators), and there are three mounts for this engine. I have the part number for the two rear mounts, but not for the one in the front. I am having a hard time finding the correct part.
Can anyone help me identify the correct part number(s) for the motor mounts for this truck and engine combination?
Truck is a 1972 LN-9000 (Warranty No: R902VP52616)
Engine is a Detroit Diesel 6-71
Serial Number: 6A257749
Model Number: 1067-8517
Rear Engine Mount/Isolator: DOHA-6068-B
Front Engine Mount/Isolator: Unknown?
Thanks!
Thanks!
I am assisting in the overhaul of my family’s dump truck. We are overhauling the engine and would like to replace the motor mounts (I am referring to the rubber mounts/isolators), and there are three mounts for this engine. I have the ID engineering number for the two rear mounts, but not for the one in the front. I am having a hard time finding the correct part.
Truck is a 1972 LN-9000 (Warranty No: R902VP52616) / 2 = Engine is a Detroit Diesel 6-71 426 cid
Rear Engine Mount/Isolator: ID engineering number: DOHA-6068-B / Ford part number: DOHZ-6068-B
Front Engine Mount/Isolator: DOHZ-6038-H replaced by E1HZ-6038-A & EOHZ-6A027-C
There's an upper and lower front insulator, same part number.
2) E1HZ-6038-A (replaced DOHZ-6038-H) .. Front Insulator but in order to use them, the round spacers (see pic) also have to be replaced / Both available from Ford
MSRP each: $58.33 / FTE sponsor: horizonpartsguy.com online price each: $42.70 / Horizon Ford Truck Center - Seattle (Tukwila) WA
2) EOHZ-6A027-C .. Spacer
MSRP each: $16.34 / FTE sponsor: horizonpartsguy.com online price each: $11.97.
2) DOHZ-6068-B .. Rear Insulator / Available from Ford
MSRP each: $71.45 / FTE sponsor horizonpartsguy.com online price each: $52.30.
Note: Horizon does not have these parts in stock, but can order them, shouldn't take more than a coupla days to get them.
Where in CA do you live? Some CA dealers have these parts in stock, but you will probably have to pay MSRP or more.
grm61
06-10-2010 05:01 AM
sidestep
10-01-2008 10:22 AM
