After Market "Swan Stem " Rear view mirrors
Hi all, I purchased some "Swan Stem" mirrors from "Bob Drake" for my 1952 Ford F1. These are the kind that have a tab above and below the door hinge. My problem is this, the Door hinge is not a "Half Round" it is oval or "elliptical" how ever you want to describe it. The "Throat" on the stems (Between the tabs) is not deep enough to allow me to install the hinge pin and rotate the stem. Has anyone ran into this problem?
I called Bob Drake and they said no one had ever told them they had a problem. Thanks, John
I ground the hinge.
A hint for "seeing" with the mirror:
Purchase a larger aftermarket rectangular head to mount in the place of the small round mirror head, big difference. Credit to Bob Jones, I followed his lead. The replacement heads are about $10 in the chain auto parts stores. They are ss.
So, I got these heads for them, and everything is fine. But I have an F4, and I need to see past the flatbed.
1948-52 Ford F-100 MirrHead. Replacement, 4852
C&G has some that might work, but you should probably call them first.
Pictures of mirrors. The first picture is a close up of an adapter that I turned out of SS to allow proper adjustment of the mirror. I made the adapters for both mirrors to improve the adjustability. Without the adapters the drivers side mirror could be adjusted but not the passenger side. I did the drivers side so that I could rotate the mirror 90 degrees from the position shown in the pix.
