Bench seat form my 53
From a 99 chevy what? Your 53 is 58" door panel to door panel (the widest part of the seat)
Here is part of and article, located here https://www.ford-trucks.com/articles...0-ford-trucks/
1953-1960 Trucks " Seat Width No More Than 58 Inches
2001 F-150 NOTE: There are several different styles of bench seats used in the late 1980s through late 1990s GM trucks " quasi-buckets, 60/40s and full benches. They all tend to have thin backs which helps to increase leg space where needed. Some have built in arms rests and a level of seat bottom sculpturing to them, some don’t. These seats are also well liked by a number of the members of this forum.
1988-1998 GM truck seats
o Excellent looking brackets
o Easy to adapt
o Headrests tend to be removable
1988-1994 Chevy Silverado bench
o No headrest
o Fold down arm rest
o Very stylish
1997 and newer F-150 bench
o Has a built in headrest
o Brackets are a bit of a challenge
Late 1990s Chevy Suburban
1987 Chevy pickup bench
The 2000 and newer Suburban
o 60/40 bench
o Removable headrests
o Not the most stylish thing
o Brackets are clunky looking
The 1999 and newer GM Silverado 40/20/40 “bench” is an interesting possibility. It’s 60 inches wide, but it’s really more like two buckets with a “jump seat” between. You could easily omit the middle section and put in a narrower console or nothing. They do have built shoulder belts, saving you the issue of mounting the shoulder restraint to the wall between the rear window and the doors. You might fit this whole set up into a 1953-1960 F-100. The 1994 through 2001 Dodge truck also has a similar set up, though less stylish than the GM version. It will have the same pluses and minuses.
Another issue to consider is that you need to build some sort of bracket to mount your new seat(s) to your truck. If you’re using the 1988-1998 GM seats, it’s pretty straightforward. Just look at the stock GM mounting brackets and it’s a no brainer. However, if you’re using Ford seats or buckets, this can get a little tricky. For a few good pictures of the brackets one member made to install a later model seat check out this thread. http://www.ford-trucks.com/forums/sh...d.php?t=114729 The work was done by KAI – our German buddy. He was putting a 1980 F-350 seat in a 1954 F-100. His brackets deal quite nicely with the weird bend/angle in the front of the stock Ford brackets. They are wonderful in their simplicity and could easily be modified to compensate for a shorter driver.
o Easy to adapt
o No headrest
o Very stylish
o 60/40 bench
oscajo
07-26-2021 04:58 PM
Pappys53
07-25-2020 03:08 AM
gt40racing
25
07-01-2018 03:44 PM
Luddle
11-20-2008 03:55 PM
