my 84 6.9 f250 lost its clutch in town. got towed home. after examining everything, I found a small crack in bottom of the slave cylinder,leaking fluid.now that I am putting in new one, how do I bleed the thing? I see no bleed valve.
I checked with NAPA, and a couple others. there is no bleed valve on this unit for this year ( 1984) truck. so, anybody know how to bleed it, after the r/r?????
thanks guys....now give me the booby prize for dumb questions and bad research. I found the bleed screw under the layer of grease and dirt. problem solved!
