C 600- Now I'm ready!!
#31
Hi Ken:
I have been busy with the engine, power steering pump and driveshaft. Drivetrain is all welded in and assembled. Radiator is ready for installation this week. Long bed sides have been welded and bent, and I'm going to NPD this morning to buy a tailgate. Not sure if they stock the ribbed front bed panel, but they have the smooth.
As soon as the radiator and support are in, I'll fit the fenders and the work my way back to the fiberglass steps.
Latest pics here.https://www.ford-trucks.com/forums/1...c-600-a-4.html
Regards, Mark.
Regards, Mark.
#32
#33
#35
#36
#37
#39
#41
#42
#44
Hi Ken, and whoever else cares:
I did fill the hole for the gas tank with the patch that Mid-Fifty sells. Since I have the 2003 E350 chassis, I can use that gas tank out back or a Mustang tank-Haven't got that far yet!
The steps from Terry's are supported by the original steel brackets, and they line right up.
I took some crappy pictures in the dark just now, so maybe you can see underneath.
Regards, Mark.
Regards, Mark.
#45
Thanks Mark,
Did you just cut a piece out of the replacement corner or use the whole thing. It looks pretty good size the way it comes. Maybe Nifty Fifties has a smaller piece. I was looking at the replacement corner. I also have a big tank behind the rear axle in mine and didn't want the gas tank inside the cab with me. Thanks for the info in advance, Good luck with your build.g
