Another Smoke question different than any I have seen
OK guys looking for any ideas that you have...
Deleted with H&S Black maxx on the wild setting not running hot tunes. EGR fully deleted and removed. DPF and CAT removed.
The truck has been blowing smoke out of the exhaust at start up and continuing for a minute or two at almost every start up unless only turned off for a couple of minutes. Smoke appears to be whitish (not blue for oil and much more white than grey). I have checked the air intake and it is pretty dang clean, I pulled the CAC apart today and cleaned boots and wiped a very small amount of oil out of the inside of the boots. It does not seem to be leaking coolant my cold level in reservoir is still full.
I just need some ideas of what to look at. It is not cold outside, temperatures have been very warm I am in Texas panhandle with temps in the 90's. It smokes at morning start up and also at noon to go to lunch and also 5 pm starting it to go home.
It only smokes for a few minutes at each start up and when I start pushing the engine and going it stops the smoking. After turning engine on and letting it sit in driveway it stops smoking after a couple of minutes.
I have read everything I can on this subject and my symptoms just seem a little bit different and I am wondering what ideas are out there.
MudhenGIB
02-20-2013 06:48 PM
kevinwebster1
11-28-2009 12:59 PM
