Ranger 4x4 Conversion
Easiest thing is to buy a wrecked 4x4 ranger as you'll need trans, xfer case, driveshafts, front axle and supporting hardware, buying these parts individually will nickel and dime you to death. Be sure the donor has the same gear ratio and trans. It'll take some work but in the end it should be worth it.
Financially, you would come out ahead by trading for a 4x4. Down time for your vehicle and your personal time involved would add up real fast, so for a few hundred dollars, I would just swap vehicles. Course, you could buy a rolled 4x4 for a few hundred dollars and spend your time working on it if that is your desire.
Unless you are emotionally attached to the current truck, sell it and just buy a 4x4. That takes all the fun out of making the swap, but it's not a fun as it seems when you are fighting rusty bolts and spending weeks trying to make it all work. 4x4 Rangers are plentiful. Just find a clean one!
