1951 F1 Panel Restore (R)
#31
That is definitely more affordable. Never saw that kit before. I think I'm going to go with a u steer electric kit. They make a universal kit and one to fit Ididit columns. Ive been thinking about using the ford A/C compressor as well. Maybe just have some trouble finding fittings for it to mate up with the rest of the VA kit. But I'm sure there is something out there.
#32
Backdraft Parts - CONTROLS PACK - 5.0L 4V TI-VCT MANUAL TRANSMISSION Here is another Power Steering kit for the Coyote engine.
#33
Evidently, you are correct, but it just happened. I read thru about 8 pages of posts full of tecnobabble and "are we there yet, Daddy?" posts spanning nearly a year, thru 8/15 and there was still no definite answer or any "It's done" announcement in the posts, or on their website so I messaged HP and asked. They answered that yes, the can now defeat PATS on the OEM ECU and it will still control the automatic tranny. I then wrote back asking just what was needed, the costs, and if this was something an average person without a strong automotive electronics background could accomplish in their home shop? I am still waiting on a response.
#34
I am stoked for junkyard coyote, 6r80 swaps. Don't think you'll see many LS swapped fords anymore. Now back to the OP thread
#35
I'm sure you probably have done your research but I see AX giving bad info so I'll chime in. HP can disable PATS which means you could use the factory ECU to control a 6R80. I've heard on forums that LUND racing can do it as well but don't have any non-internet knowledge if its true. That 6R80 is massive though and i'm sure would require a huge tunnel so i think the 4R might be the better choice but it'd still be cool to have a 6 speed auto in a old truck.
And I'm really liking the progress on your truck.
#36
#37
Since I now own a 4R75W, that's what I'll use with the Coyote.
Yesterday was spent blasting the inner fender panels. Then hammering out all the folds and dents to make them fit. I seem to have a vehicle that was wrecked in the past. The front clip was probably from a '52. At least the hood is a '52. The frame is stamped F1H1CHXXXX So it's a '51 F1 originally with a 6 cyl engine made in Chicago
#38
#41
Coyote motor is here! 2015 with 186 miles.
2010 4R75W, Heavy duty rebuild.
Does anyone know if the F150 flexplate used for the 6R80 Ford trans, will fit the 4R75W?
POR 15 primer on the running boards. I never could blast off all the traces of rust. I will use truck bed liner as a finish coat.
#42
Nice! Perfect time to enjoy some BEvERageS and admire .
I can't answer your question with first hand knowledge. But in this link these guys install a 4R75W to Coyote. Bullet point #3 makes me believe it will work. Ford 5.0L Ti-VCT Engine. They don't mention changing it.
#43
I'm located in Morgan
#44
Engine and trans together, sans torque converter. For test fitting.
Test fit into frame.
Test fit with inner fender panels. I have since removed the truck exhaust manifolds and put on a set of Mustang GT stock exhaust manifolds. A better fit and have the O2 sensor bungs. I am having problems getting the engine low enough in the front. The oil filter housing hits the PS hydraulic lines. Going to look at options on a remote oil filter, or re-doing the PS lines with lower bends. As it is the trans yoke angle is 5 to 6 degrees and going to cause driveline phasing problems.
#45
Test fitting into the frame. I have since removed the truck exhaust manifolds and put on Mustang GT exhaust manifolds. They are lower and already have the O2 sensor bungs. A better fit.
Test fit with the inner fender panels. I need to get the front of the engine lower, but the oil filter housing is hitting on the PS hydraulic lines. I may need to redo the lines with different bends, or look into a remote oil filter setup. As it is the trans yoke angle is 6 degrees. Going to be driveline phasing problems if I don't lower the front of the engine.
