Aluminum Radiator and Fan Shrouds
I recently purchased a rebuild 1979 f350 with a 460 engine. It has an aluminum radiator with a stock fan but no shroud.
Problem is it starts to get hot when sitting at idle.
Will adding an aftermarket shroud be better than a electric fan? I've heard the shroud makes a big difference in cooling at idle.
I have no issues while moving, the aluminum radiator works great.
Cool while rolling usually means the radiator, WP and rest of the setup is OK. Good start.
Hot at a stop usually means not enough air flow. A shroud really helps at stop and low speed. An electric fan needs one also and is often built in. A shroud should help quite a bit.
What will work/fit depends on your radiator. I run a Champion aluminum radiator on my '78/400 and the OE shroud fits great. Also cools great. If you have a Champion, the stock shroud should fit. If other radiator may need some adaptation.
I'd suggest you look for a stock type shroud (JY, Bronco Graveyard, LMC truck ect.). A high capacity OE electric fan setup can work fine also and needs significant charging and wiring upgrades. Personally, I prefer the simplicity of the mechanical setup. I added a thermal fan clutch to mine for less noise and (a bit) more efficiency. OE was fixed fan/no clutch.
Thanks - I have a super shroud for my aluminum radiator from Bronco Graveyard. I will install it and see how it runs. Was more curious is that would outperform an electric fan.
From what I read and hear, sound like a shroud with mechanical fan should work well and create enough pull to stay cool at idle.
proeliator
03-19-2003 03:29 PM
