loud hp fuel pump
loud hp fuel pump
Last year i replaced my high pressure fuel pump with a cheap one (was in a bind). Now its really loud. I have a cherrybomb on my truck and i hear the whinning over that. Yes its that loud. Also i removed my fuel res/tank switch for a while, i replaced it yesterday. Ive been having a really bad misfire at the low rpm range and at idle. Im running lean as well. Could this be because of this cheap and possibly bad fuel pump? Also i replaced my plenum a few months ago and it is full of carbon buildup, could that be the problem instead?
i figured it out. it was my darn dizzy rotor. it was all corroded so i took my knife to it and cleaned it up. fired right up and no misfire. every time ive had this misfire ive always thought it was a vacuum leak so when i would change my plenum gasket i would remove the cap and rotor to make more room and in the process clean off the cap and rotor with my knife. when i would start it then she would run great and all along i thought it was my plenum gasket. cant believe something as simple as a corroded rotor can cause this big of an issue. and it would get worse over time
anthonym92
05-31-2017 05:38 PM
