Question after removing overload springs
I have done a half hanger flip and removed the overload spring. Now when I put my truck in forward gear and give it gas the front of the rear end tilts up and if I put in in reverse it tilts down. Is this normal with the overload spring removed ? Or is it something I need to look into ? Do I need to put it back ?Or is it a completely different issue ?
Thanks
Thanks
I am unsure if it is causing it or not but I did pull the driveshaft and I only had 1/2" of play. Do you think that may be the cause ? Even if it isn't the cause it seems I should figure out a way to get another half inch. Has anyone that has removed the overload had this issue ?
Thanks again guys I appreciate your time and suggestions
How much play is there sitting on the bump stops? If you can go through the full suspension range with about a half inch I think your ok.
I still fail to see how the DS with 1/2" play right now can cause axle wrap? It would seem much more likely to be prone to axle wrap with out the over load spring as you only have I believe 4 regular leafs left, then the axle perch is very short on top of that.
Dano78
04-06-2022 09:23 AM
fordf350camper
11-28-2012 10:21 AM
Herman R
08-19-2007 03:45 PM
