valve guide replacement on 7.3 diesel
Old 08-14-2015, 11:48 PM
JosephDunivan's Avatar
JosephDunivan
JosephDunivan is offline
how hard is this job going too be need all imput thanks joe
Old 08-15-2015, 06:04 AM
Tom's Avatar
Tom
Tom is online now
Morning Joe.
I'm moving this one to the 7.3L forum. What makes you think you need valve guides?
Old 08-15-2015, 12:20 PM
JockD's Avatar
JockD
JockD is offline
The original guide is cast into the head. To replace it the head is drilled and reamed so a new guide can be pressed into place and reamed. The valve seat must be touched up to ensure that it matches the axis of the new guide.
If the original guide has been replaced as I described above, that guide can be pressed out and a new one pressed in and reamed to replace it. The valve seat must be touched up again.
Most replacement guides are precision enough that the reaming process doesn't remove any material, but reaming is necessary to ensure that pressing the guide into place didn't distort anything. It takes special equipment and tooling to remove the original guide without altering the alignment to the valve seat. A good automotive machnine shop should have everything needed for this job.
Old 08-15-2015, 03:00 PM
JosephDunivan
oh boy thanks please send usmc to asst lol thanks joseph
Ian Roach
1983 - 2012 Ranger & B-Series
08-10-2019 09:51 PM
FordOwnerJoey
11-14-2014 06:04 PM
redrivergorge
04-06-2014 01:12 PM
71fordkid
3.0L V6
04-16-2007 06:28 PM
Kiwi351
06-06-2001 09:43 PM
Quick Reply: valve guide replacement on 7.3 diesel
