Black smoke coming form carburetor
Old 08-14-2015, 04:23 PM
Moiford's Avatar
Moiford
Moiford is offline
I have a 1956 Ford f100 that I'm restoring an I checked the timing and the spark plug fires just on time. I have it cranking and gas is flowing in to the engine but I can't get it started and black smoke keeps blowing through the carburetor. Whats causing this?
Old 08-14-2015, 04:53 PM
harleymsn's Avatar
harleymsn
harleymsn is offline
I could be wrong, but my first though is that you it have 180° out of time.
Old 08-14-2015, 05:17 PM
Moiford's Avatar
Moiford
Moiford is offline
Is that even possible? My grandfather had it running fine 6 years ago, I don't think the timing chain is broken but I haven't checked it.
Old 08-14-2015, 05:18 PM
Moiford's Avatar
Moiford
Moiford is offline
It's not a lot of smoke
Old 08-14-2015, 05:28 PM
harleymsn's Avatar
harleymsn
Has the distributor been removed since then?
When you say the timing is correct, was that verified with a timing light?
Old 08-14-2015, 05:59 PM
Moiford's Avatar
Moiford
Moiford is offline
I haven't removed the distributor and yeah I used the timing light my timing was good.
Old 08-14-2015, 06:04 PM
raerjim's Avatar
raerjim
raerjim is offline
Black smoke coming from the carb???
Old 08-14-2015, 06:16 PM
harleymsn's Avatar
harleymsn
What engine and transmission does the truck have? What is the timing that you got? ( in relation to timing marks) Do you remove the vacuum advance line when checking timing?
Old 08-15-2015, 12:39 AM
Moiford's Avatar
Moiford
Moiford is offline
Transmission was broke on the truck so my granddad replaced it so I don't know, but it's a 292. I haven't gotten the truck to run but it does crank and barely starts, but while it does that when I don't open the throttle, air and fuel comes off the top where 4 holes are, and when I open the throttle all the way, black smoke comes out the choke.
Oh yeah and whats the vacuum advance?
Old 08-15-2015, 01:07 AM
harleymsn's Avatar
harleymsn
The vacuum advance is a vacuum line from the carb to the distributor.
EDIT: The top of where, what 4 holes?
Old 08-15-2015, 01:29 AM
Moiford's Avatar
Moiford
Moiford is offline
I looked in my manual the four holes are called "main well air bleed" and "aspirating air bleed"
Old 08-15-2015, 02:21 AM
harleymsn's Avatar
harleymsn
Ok, so you have gas and air coming out of the top of the carb? And black smoke coming out of the carb when you open the throttle?
I was hoping one of the Y block guys would pipe in here, but that sure sounds like timing off 180° and it's exhausting through the carb.
Are you sure the wires are on the proper post and plugs?
Do you understand the proper firing order?
When using a timing light are you sure it is attached to the #1 plug? ( front plug, passenger side)
Old 08-15-2015, 02:40 AM
Moiford's Avatar
Moiford
Moiford is offline
Dang really? My luck, how'd that happen? I know the firing order and I'm really sure I have it plugged in the right order, I'll check in the morning. And yeah I properly did the time light.
By the way how would I fix the timing?
Old 08-15-2015, 07:18 AM
scrape's Avatar
scrape
scrape is offline
sounds like exhaust, a mouse hasn't set up home in the exhaust have they and blocked it
could the egr cross over leak into the intake ports?
Old 08-15-2015, 08:04 AM
Steve's Avatar
Steve
Steve is offline
This is a y-block firing order and distributor wire location diagram.
Quick Reply: Black smoke coming form carburetor
