No trailing arms it's an independent rear. I bet it's from the bushings. Mine squeak a bit to. Sprayed them with silicone a couple times but it came back so I stopped bothering
Not sure if you resolved this. I recently had a noise in the right rear passenger side. Found the hardware for the parking brake pads came off and were rattling around inside and jamming. Replaced pad with new hardware kit. All is good.
